jakethesnake
I Am The Snake
- 6:32 PM
- Feb 5, 2016
- Here & Now
Use semi sir That is giving noise it honestly will help sir
LOL need a hand saw.What a piece of junk, for the most part.
My TriLink loop won't self feed worth poop!
There is something profoundly wrong with these chains, they will not bite at all.
FYI, I lowered the rakers today, no positive change in cutting behaviour - this loop is as agressive as a dead snail!
The only odd thing is that it kinda holds its poor "edge" for a full tank of fuel in dirty oak logs - that is worth 30 minutes of bucking with my PS-7900.
A small touch up will help it hold its poor "edge", and by touch up I mean 2-3 free hand file strokes upon refueling the saw.
I am disappointed with this TriLink loop, and I have a couple more.
I have some pictures on my phone, I'll get them up when I'm on my PC.
It's not Carlton?Just FYI .... Woodland Pro .325 NK is tri link chain .
The stuff I got had the three little link looking things on it . ( . 325 narrow kerf ) it was in W P boxes .It's not Carlton?
Philbert
You have seen pictures of loops that "I" consider worn out!Chains break. That is what the chain catcher, flat guard under the rear handle, gloves, and caps are for.
Glad that you only got a scare!
Philbert
try some raisman chain on hl supply i have been hearing good things about the chains and they are cheaper than Oregon which must be expensive in CroatiaHave You noticed the wear difference between the friction surface of the cutter plates and the tie straps?
Cutter plate seems to be much harder, doesn't it.
Oregon is the 3rd most expensive chain in my area behind Dolmar & Stihl.try some raisman chain on hl supply i have been hearing good things about the chains and they are cheaper than Oregon which must be expensive in Croatia
Checked with feeler gauges and a flat file over three teeth with the chain sitting in the bars groove.Looks like you at least got some wear out of that chain!
Curious what your depth gauge offset measures.
Philbert
