- 12:17 PM
- Sep 4, 2018
- Central Kansas
Sure is nice to have those in board clutches like you mentioned!
And there is always falling into the wind with no wedges in your back pocket ,would have been worth a walk back to the truck .I now don't cut anything without wedges near by ,was doing fine till the one gust cracked the hinge and blew this cedar back on my bar .Don't do this . I had to recut the tree above this cut to get it down ,did not lose the bar ,pinched the nose rails some but my bar wrench was able to open them back up .On some saws with inboard clutches you can remove the powerhead so don't smash your saw if things decide to go wrong ,think i had an ms440 on this one .
This was years ago ,i think i had to loosen the adjuster screw after got the bar nuts off, i i think it was tight on the sprocket still.Sometimes you can stick your bar wrench in the bar stud slot and pull it out while the tree sits on your chain. Other times there’s just to much weight and back lean and it’s completely stuck lol
You just said alot of good things. Very many.I agree. Especially if you have enough back lean on a tree it can be tough to pound wedges the whole way if you haven't been working them in all along. It also helps you read the tree. If you keep cutting then tap wedge then repeat you can gauge how bad it's leaning or moving ahead or whatever. Save all the wedging til the end and that's pretty tough to know how much work you have to do, hinge you need, etc... Not saying I've never cut a tree up nearly all the way and then wedged. Depends on size and situation too. Just ease it in in some cases instead of forcing er in.
Well I didn't want to come on too strong...You just said alot of good things. Very many.
Yes for sure, If you don't do cycles of cutting and reloading your wedges then you are throwing away your advantage of easy wedging stages that aren't always there at the end. There is a fine line on trees you do it on and or over doing it too early when not needed in that stage. Ultimately you want to be one step ahead so when the weight is transitioning as we cut they are preloaded for a lift. The mindset at this stage has to be, if it has the ability to set back with all that wood then it must have the ability to go forward. This is the stage you are talking about getting a gauge on how hard the lift will be before it is completely cut up.I agree. Especially if you have enough back lean on a tree it can be tough to pound wedges the whole way if you haven't been working them in all along. It also helps you read the tree. If you keep cutting then tap wedge then repeat you can gauge how bad it's leaning or moving ahead or whatever. Save all the wedging til the end and that's pretty tough to know how much work you have to do, hinge you need, etc... Not saying I've never cut a tree up nearly all the way and then wedged. Depends on size and situation too. Just ease it in some cases instead of forcing er in.
Yes sir small diameter will make anyone look foolish.Yes for sure, If you don't do cycles of cutting and reloading your wedges then you are throwing away your advantage of easy wedging stages that aren't always there at the end. There is a fine line on trees you do it on and or over doing it too early when not needed in that stage. Ultimately you want to be one step ahead so when the weight is transitioning as we cut they are preloaded for a lift. The mindset at this stage has to be, if it has the ability to set back with all that wood then it must have the ability to go forward. This is the stage you are talking about getting a gauge on how hard the lift will be before it is completely cut up.
I guess it's one of many feels that you get by production falling. As we say : "It will talk to ya".
It happens a lot and is likely a tree that I've convinced myself that is going to start out hard pounding once it's fully cut up and I get a feel for the wedge movement on the last cycle or so. The leverage is drastically increasing as the wedge points and holding wood distance increases . Basically more wedge movement = less lift per movement = easier and you are moving further so it can't be a bad sign.
When nothing seem to change then you know you are in for a good one.
Not a lot of leverage when the wood is close to the wedge still with feet left to cut. It is a enough to load up the fibers and repeat or wait a bit longer after you set them. It's all a bit different.
As you mentioned, you would have further to move it. The first stage of the lift is for sure the hardest once the tree is all cut up so it gets you off the ground floor a head of time.
Sometimes smaller trees can be the hardest just by the distance it moves on short leverage points especially if they sat back without your saw in there. They sure sit back further too. I tried wedging small Hemlocks saplings that sat back from the side by the hinge and the axe just bounced off with a new 10" k&h. The top sags over too. Pine I can do it with taller spindly ones with top sag.
An 8" back cut to undercut of tree will move three times what a 2ft will and 6 times what a 4ft will.
You only going to move about 2° and thats a stack wedge with a 4ft back cut . A bit more limiter anyway with 170ft of overhang.
I never hear anyone say "Timber" when the tree starts to tip anymore .
I have never jacked one over yet ,it looks time consuming.I've got one or two on video somewhere. I said it once, someone else said it once. Mine was more of a joke, because the wife of the landowner insisted she take video of me jacking one over. She was standing about 100 yards away. It was on the small side (20" or so)and the jack was pretty near the hinge. It took 15 minutes of screwing around to put it down. I had a road behind and narrow window to put it in. I was so frickin happy when it started to go finally I had to yell timber. That and they were standing so far away it was comical.
It's really not that bad as long as it's not too windy. It takes patience more then anything.I have never jacked one over yet ,it looks time consuming.
You've been running 390s for a while. They are new to me. The run really well but it seems like all I get done doing is replacing parts.Woods has been wet since break up so I've been finding work in town. Big ugly Chinese elm.
I am not sure how it could ever be a concern on a 30" full length green tree. Anyway I get the point. Why do you want a deep undercut when you are wedging unless they are light without dangerous tops or stubbies when you want to manipulate the weigh and or tip them quicker. It can be OK on bigger green tree if it's really close one way or the other to try and sway the center of gravity your way. If you miss she will kick over quick without too much trouble. Guide lines are 25% target so then consider your situation.This was a humboldt face followed by a regular back cut ,maybe 30% face cut ,left room for the wedges to go in all the way for lift ,it was a hill side so ground on other side of cut was about 8 feet down so cut it from the high side of the hill ,if i would have cut a deep face ,i would have ran out of room for pounding to get the tree to tip sideways on the hill
I see an assortment of wedges in which none are lifting wedges. The thicker 12" should be a chasing/ release wedge and the sleek 10" K&H are leading/lifting wedges.,this is where the wedges were when it went over ,i pounded it over with a 3 lb axe ,so there must be some math in there for lift vs speed vs something else ,or could just say the turtle was faster than the hare this time .
What are you replacing? I've been running them exclusively for 7 years now. I usually buy one a year and sell the old ones off to firewood guys.You've been running 390s for a while. They are new to me. The run really well but it seems like all I get done doing is replacing parts.
