- 2:08 PM
- May 30, 2016
- Ct
We punch out the centers on certain trees after cutting the notch to prevent fiber pull and splitting. We don’t do it on all of them though and I wouldn’t bother doing it on firewood, only saw logs. Attempt at your own risk. It works well on ash and hickory. It also helps you out if the tree needs to roll off another one, breaks off the stump and rolls without tearing fiber. I wouldn’t do this on white pine or hemlock though, the wood is weak and you need the hinge strength. Getting out of there fast and to the side of the tree is always a good practice as you found out sir.Yes sir a humbolt would’ve prevented it. But what I’ve experienced with humbolt on ash is that it pulls deep fiber almost every time. If I were cutting this for firewood it would’ve been a humbolt, but this was for the mill.
By small step I assume you mean using a snipe cut on the under cut??
