Scotty Overkill
Serial Tree Killer
- 9:05 AM
- Jun 14, 2016
- central PA
You coming to Duane's next month?We need a GTG Dang It!
IDK.You coming to Duane's next month?
around here you see tons of stumps with the ol sloping back cut from *dipsticks at the road commission.Looks like the tree work around here.
You’re lucky if they even face notch around here they usually just cut in half way then start on the other side and try to meet the cuts up.around here you see tons of stumps with the ol sloping back cut from *dipsticks at the road commission.
Yeah lots of hack and slash cutters around, here too.This is East coast. This stump is from what equates to an old growth cutter out west, demographicly speaking.. As shocking as that is. Makes no sense because the first run was trashed from the wood pull. He cut the slivers but you can see how much of the heartwood was pulled out. The first run is about all there is on such a tree.
I would've cut them as the brown fence is my house. I was in a different state when they went down. There's a bigger poplar stump down the hill that is so off plumb, I dont think you could stane on it without new nails. Of course, it had a giant post that pulled out of the butt.
probably a good Idea not to learn from someone who makes stumps like that.
View attachment 377375 View attachment 377374
I'd agree, pretty bad@dik650 i don’t think you can classify that as any type of cutting. It’s someone who doesn’t know the first thing about cutting and is blindly hacking away and ripping it off the stump. I can’t make out a face or anything. It’s all angled up.
Scary huh?@dik650 i don’t think you can classify that as any type of cutting. It’s someone who doesn’t know the first thing about cutting and is blindly hacking away and ripping it off the stump. I can’t make out a face or anything. It’s all angled up.
My plunge cuts are mismatched most of the time as well, and quite honestly, doesn’t affect anything when it comes to directional felling on hardwoods for me. As long as the notch and hinge wood is correct.I'm no gol advocate, when I try I mismatch the cuts
Incredible. I still can’t see any kind of logic or reasoning in that stump.Scary huh?
The guy has been in business, selling to the local mill, for like over 40 years.
Most of the old guys have graduated from straight up stumpjumping to this bottom tier GOL stuff.
Also 95% of the time the face is on the downhill side. No different here.
That's called a farmer's notch hereThis is East coast. This stump is from what equates to an old growth cutter out west, demographicly speaking.. As shocking as that is. Makes no sense because the first run was trashed from the wood pull. He cut the slivers but you can see how much of the heartwood was pulled out. The first run is about all there is on such a tree.
