rocketnorton
- 5:22 AM
- Jan 21, 2016
- surrey, bc, can
homemade s/n.
too cheap to buy # set.
Well did you get the 051?051 has what ignition on it?
Would like to know if one at a OPE shop is worth dragging home. [emoji848] Supposed to be a runner. [emoji57]
Anyone over here have experience with the Walbro WA-2 diaphragm arrangement in an 031 application? Both Stihl and Walbro IPLs show both a pump diaphragm and what appears to be a check valve diaphragm (they call it a surge/suction chamber diaphragm) but the cover pegs will only accommodate the hole arrangement from one pump side diaphragm out of all the ones included with both the D10 and K10 WAT kits. There was only one in the carb when I pulled it apart and it didn't run for crap. Still doesn't after a USC bath and new kit with the same single pump diaphragm arrangement it had when I got it. Sorta stuck at the carb for the moment before diving further into it. Pressure/vac tested tight as a drum. New fuel line and filter. New condenser. Clean points at .016. Great spark. Fires right up. Just won't run for squat or idle. No spare carb handy for a comparison or I would have already done that.
TIA for any enlightenment as usual. If you're around @Glock37, I've read you know these inside and out and may be able to shed some light. Much appreciation for anyone who can. Thx.
Most rebuild kits have different gaskets and diaphragms. They fit a variety of applications. Have had some that didnt cover the special one that I had.
It’s an 051, smaller tank than the 075/076 and no auxiliary Oiler. May or may not have a compression release and the 075 has through studs length of cylinder with a nut holding the cylinder down. Also one of the newer 051’s since the oil fill is on the side like an 076 not on top like an 075Not yet. I need to positively identify it first.
I think a lot of the Oregon aftermarket carb kits have the extra diaphragmFound the OEM Stihl supplemental kit with the additional 'suction chamber' diaphragm. NLA from Walbro but was included in older D and K10 WAT kits. Crap shoot if you'd actually get one these days. Would depend on the age of the kit.
Don't give up on that 032. Should be able to find anything it needs fairly cheap.
Let me know exactly what the diaphragm youre looking for looks like if you cant find it.I think a lot of the Oregon aftermarket carb kits have the extra diaphragm
