Maintenance Chief
9:05 AM
South Carolina
You can buy a new pump piston for it. Have you inspected the oil pump worm gear? I'm assuming the adjustment is turned up?
Its turned up , I was hesitant to disassemble it with out a replacement on hand but I ordered a 1124 007 1029 kit which includes the gears.
When rotating the gear by hand it has a weird spot in it so it might be wiped out.
jacob j.
Lord of Cargo Pants
6:05 AM
Coastal Oregon
Most likely thing is either your worm gear is worn, or the tension spring/tang is spinning somewhat freely on the body of the worm gear. It may also be that the tension spring/tang is worn down
on the end where it engages the clutch drum and is not fully engaging.
peter92
11:05 PM
maryborough qld aust
Morning all
just cleaned all my parts for the 038 Magnum 72cc rebuild
waiting on the donor saw to turn up to get the 52mm cylinder
did notice one thing the RUBBER MANIFOLD BOOT for the saw from stihl is $69AU , wow so was hoping some one on here nows where i can get one and delivered to Australia cheaper than that
Peter
9:05 AM
Well just get on flea bay and buy it yourself . Nothing to it,I've bought stuff from flea bay Germany and England .
Okay a story .A few years ago while working with a German installation crew installing 350 million dollars of a new auto assembly line one of the guys needed a Kohler engine for Bob Cat skid loader with a worn out engine he owned near Essen Germany .I found the cheapest new one in the USA in Indiana and a good used unit 30 miles from where he lived .He bought it for a fraction of new cost,installed it when he went back for two weeks of vacation and did all the transaction on a smart phone half way around the world in about 2 minutes .
peter92
11:05 PM
Thanks Al , might just have to get the part from the STIHL DEALER her in AUs
Peter
lehman live edge slab
Live Action
8:05 AM
Mn
It had lots of torque which made a nice steady pull with a 32”. Welding isn’t the nicest carbon and hard wire with the wire feed but it worked.
RI Chevy
9:05 AM
earth
Hows the oiler? It oils a 32" bar?
