Tecomec pistons (PORTING HELP)
1:33 AM
HF just had their grinding tool on sale for $6.99, but if you missed it, it is regularly $8.99! I printed my degree wheel off the net. The folks on this site have already done all the heavy lifting and will give you advice. It is now just a matter of wanting your saw to run better!
That said, my best running saws have been sent out, but I have improved performance quite a bit, right here, by myself (with advice from others). It is work, but the rocket science part has already been done.
A great running saw just puts a smile on your face!
Mkinslow
12:33 AM
Tennessee
You are correct sir. They have done all the experiments and are very willing to help,I just need to get motivated , start finding the tools and get to figuring out how to do it.
Mkinslow
12:33 AM
Tennessee
I've got a dremel hand piece that I do a lot with, but I can't see how I'd get in and around the exhaust/intake ports unless I just do it with a ball type. I'd imagine some can be done from outside in.
XP_Slinger
They’re Just Saws
1:33 AM
Central NY
I’m a Dremel warrior too and outside/in is exactly how you get it done. 3” shank burrs are mandatory. Chamfer with a tapered stone bit. Transfers can be tricky if you don’t have removable covers. And the smaller the bore the more screwed you are with transfers and a dremel. I managed to work my 357XP “good enough” but any smaller bore than that and it really doesn’t work.
Mkinslow
12:33 AM
Tennessee
Where did you get you 3" bits
1:33 AM
I like to use the diamond balls for the chamfers, ebay has lots of low cost 1/8" shank stuff. If I need to lower the intake I will often do it with a half round file. Exhaust ports I do from the outside in, watching from the inside.
Transfers can be tough, but if you remove the plating with a diamond burr you can use a stone to remove aluminum, giving you a 90* angle.
If you think it through, it can be done.
But even before porting, a muff mod, timing advance +/or base gasket delete can really wake up a lot of saws. Some of them will run like they are ported.
If your transfers look good, leave them alone, you can mess things up. Get a good set of timing #s from someone who has experience with your model saw, check where your #s are, and come up with a plan.
I just checked a 066 jug with a Meteor piston on a Asian 660, w/o base gasket. Sq is only .010, Ex 98, Tr 122 and In 80.5. I think the #s are good, so I am going to sand .010 from the squish and widen the top of the exhaust and leave the rest of it like it is. I also filed .020 off the key to advance the timing a bit.
Once you start, and see the gains, it is addictive! I did several of the 440 BB kits, each time adding a few addl mods, and as the performance increased it encouraged me.
Good Luck with it.
1:33 AM
066 with timing wheel I printed from the net, backed with carboard and some closed cell foam to grip the axle (also taped).
Mkinslow
12:33 AM
Tennessee
Good Luck with it.
Thanks for the encouragement bud. I'm gonna start looking and see what I can find. Once I get some stuff I may try it on my 2159 since I have an extra used cylinder for it. Then progress to another one.
Mkinslow
12:33 AM
Tennessee
What shapes of burs do yall normally use. I'm seeing quite a few options
Mkinslow
12:33 AM
Tennessee
Got something done with this project today. Got my degree wheel made up
1:33 AM
Now just make a wire pointer that bolts to the case that you can adjust. Then use a piston stop and rotate both ways, adjust TDC to the middle.
Intake opens from the bottom, exhaust and upper transfer from the top. I use my bright bicycle light to see the upper transfer through the exhaust.
Mkinslow
12:33 AM
Tennessee
Doesn't matter where on the case as long as it can be zeroed, right. I still gotta stop at hardware store tomorrow and pick up some stuff to finish with. Ordered a ball burr and egg shaped burr 1/8" shank by 3"long today. Those on Ebay look like 1/4 shank. I've got die grinders but I'd rather use my dremel. Wonder if they come in 1/8.
