Yes.Did you port that one bud
You are correct sir. They have done all the experiments and are very willing to help,I just need to get motivated , start finding the tools and get to figuring out how to do it.HF just had their grinding tool on sale for $6.99, but if you missed it, it is regularly $8.99! I printed my degree wheel off the net. The folks on this site have already done all the heavy lifting and will give you advice. It is now just a matter of wanting your saw to run better!
That said, my best running saws have been sent out, but I have improved performance quite a bit, right here, by myself (with advice from others). It is work, but the rocket science part has already been done.
A great running saw just puts a smile on your face!
I've got a dremel hand piece that I do a lot with, but I can't see how I'd get in and around the exhaust/intake ports unless I just do it with a ball type. I'd imagine some can be done from outside in.HF just had their grinding tool on sale for $6.99, but if you missed it, it is regularly $8.99! I printed my degree wheel off the net. The folks on this site have already done all the heavy lifting and will give you advice. It is now just a matter of wanting your saw to run better!
I’m a Dremel warrior too and outside/in is exactly how you get it done. 3” shank burrs are mandatory. Chamfer with a tapered stone bit. Transfers can be tricky if you don’t have removable covers. And the smaller the bore the more screwed you are with transfers and a dremel. I managed to work my 357XP “good enough” but any smaller bore than that and it really doesn’t work.I've got a dremel hand piece that I do a lot with, but I can't see how I'd get in and around the exhaust/intake ports unless I just do it with a ball type. I'd imagine some can be done from outside in.
Where did you get you 3" bitsI’m a Dremel warrior too and outside/in is exactly how you get it done. 3” shank burrs are mandatory. Chamfer with a tapered stone bit. Transfers can be tricky if you don’t have removable covers. And the smaller the bore the more screwed you are with transfers and a dremel. I managed to work my 357XP “good enough” but any smaller bore than that and it really doesn’t work.
This is the best source I’ve found for long shank bits of various cutter design and shape.Where did you get you 3" bits
Good deal thanksThis is the best source I’ve found for long shank bits of various cutter design and shape.
https://www.mcmaster.com/
Thanks for the encouragement bud. I'm gonna start looking and see what I can find. Once I get some stuff I may try it on my 2159 since I have an extra used cylinder for it. Then progress to another one.I like to use the diamond balls for the chamfers, ebay has lots of low cost 1/8" shank stuff. If I need to lower the intake I will often do it with a half round file. Exhaust ports I do from the outside in, watching from the inside.
Transfers can be tough, but if you remove the plating with a diamond burr you can use a stone to remove aluminum, giving you a 90* angle.
If you think it through, it can be done.
But even before porting, a muff mod, timing advance +/or base gasket delete can really wake up a lot of saws. Some of them will run like they are ported.
If your transfers look good, leave them alone, you can mess things up. Get a good set of timing #s from someone who has experience with your model saw, check where your #s are, and come up with a plan.
I just checked a 066 jug with a Meteor piston on a Asian 660, w/o base gasket. Sq is only .010, Ex 98, Tr 122 and In 80.5. I think the #s are good, so I am going to sand .010 from the squish and widen the top of the exhaust and leave the rest of it like it is. I also filed .020 off the key to advance the timing a bit.
Once you start, and see the gains, it is addictive! I did several of the 440 BB kits, each time adding a few addl mods, and as the performance increased it encouraged me.
Good Luck with it.
Oh ok. Sorry I really haven't got to look at them too much yet. Dang kids school programs and all that crap lol.The ones I posted are 1/8.
Doesn't matter where on the case as long as it can be zeroed, right
