Stihl MS881! The rumors begin
lehman live edge slab
Live Action
4:44 AM
Mn
I did find the real spec of 11000 when I looked more the video was leading people to believe that max power rpm was the max rpm out of wood
broadwayline
5:44 AM
Ontario, Canada
Thought there was pictures of a jug inside on here somewhere
How do I upload videos to this joint?
The limiter hits very hard on this saw - feels like an mtronic limiter but it isn’t an M saw - nothing like the coil limiter on the 461 anyways
deye223
AIR FUEL SPARK VROOOOOM
7:44 PM
Australia
Upload your video to YouTube copy the link then go to post reply and just above where you type your reply you will see the icon for :) third one across to the right you will see two diagonally opposed squares click on that paste your link where it tells you to job done
5:44 AM
The 3 441’s I have had here before were limited. Both non Mtronic and mtronic. Seemed around 13,200 it kicked in. Not sure if they make a unlimited 441 coil. 13,200 is probably high enough for a 880 worksaw. That is if the coil bolts on and works.
