- 8:00 PM
- Jan 26, 2016
- South west UK
I have 35" handles on my felling axes (3 to 3.5lb head).Just put a handle in this one it feels nice it's a Kelly 3lb'er at the moment the handle is 33" is that a bit long
what is the best length for this weight axe
looks good did you do it at work today ?Here's a GBA 2.5 lb I just made a handle for. My first real attempt at making one. So I wasn't very picky on grain direction but I've seen worse at the store. This thing turned out much better than I ever thought, so check it out. Pretty much all done with a rasp and about 6 hrs [emoji12]
Nice job Rodney, that is really cool. Your going to be giving Buckin a run for his money.Here's a GBA 2.5 lb I just made a handle for. My first real attempt at making one. So I wasn't very picky on grain direction but I've seen worse at the store. This thing turned out much better than I ever thought, so check it out. Pretty much all done with a rasp and about 6 hrs [emoji12]
Last nite and finished it up tonite. First coat linseed oil on itlooks good did you do it at work today ?
Well thank you Sir [emoji14]oh *B-S.... it looks good dammit
Looks better than most I've seen in hardware stores. Nice axe head too.Here's a GBA 2.5 lb I just made a handle for. My first real attempt at making one. So I wasn't very picky on grain direction but I've seen worse at the store. This thing turned out much better than I ever thought, so check it out. Pretty much all done with a rasp and about 6 hrs [emoji12]
I also prefer the upper end of the handle slightly extending pass the top of the axe head. Is the center wedge wood or metal?Here's a GBA 2.5 lb I just made a handle for. My first real attempt at making one. So I wasn't very picky on grain direction but I've seen worse at the store. This thing turned out much better than I ever thought, so check it out. Pretty much all done with a rasp and about 6 hrs [emoji12]
Handle length? 26-28"?Here's a GBA 2.5 lb I just made a handle for. My first real attempt at making one. So I wasn't very picky on grain direction but I've seen worse at the store. This thing turned out much better than I ever thought, so check it out. Pretty much all done with a rasp and about 6 hrs [emoji12]
Wood, walnutI also prefer the upper end of the handle slightly extending pass the top of the axe head. Is the center wedge wood or metal?
Very nice!Picked up a couple yesterday. Small Keen Kutter and a True Temper flint edge.
