- 7:03 AM
- Jan 24, 2017
- Berkshire County, Massachusetts
Jason tells me my Dolmar has a lot of compression lol
I make the best running saws with a oem piston.
The husky pistons are heavy and unless you shim the pin bearing it could be a problem,I had a couple fail in 066's so I'll never use one again,besides a meteor 064 piston has more skirt than you need.
Also on a 064 that already has a thin base then take .100 off and it's paper thin.
Oe piston all the way
Any ignition will work but if you get a 066 cylinder with 200lb of compression and the exhaust at 102-3 you can't start it.Any experience with the 1201a flywheel and the 046 coil? Forget the part number now... Wiggs posted a few years ago about it working so now I have two. They work, but can bite ya. They both have D handles.
My 084 with the 1305/6 ? unlimited coil was like that.This is the the saw that will get you everytime
I had to get heavy rubber gloves to start it because I didn't have any skin left on my hand and it hurt bad enough that I couldn't grip.My 394/066 hybrid gave me nerve damage in my hands. There's not much that seems to hurt worse than gripping and ripping with all you got and then suddenly you're crippled from your forearm all the way down to your middle fingers. It takes the pain a good minute to peak and start coming back down before you can see straight again.
Don @sawfun watched me do it one of the worst times I've ever done it.
Send it my way, wouldn't want you injuring yourself.My 394/066 hybrid gave me nerve damage in my hands. There's not much that seems to hurt worse than gripping and ripping with all you got and then suddenly you're crippled from your forearm all the way down to your middle fingers. It takes the pain a good minute to peak and start coming back down before you can see straight again.
You would know what those are likeyou guys must have jacking soft hands is all i can say
