Barneyrb
- 3:14 PM
- Dec 27, 2015
- Way Down South
You can never go wrong by doing the right thing
Some of the west coast fellas charge $400 for port work and don't machine anything at all.Porting value:
for all the porters out there.....
at what point do you change what you charge for porting a saw? I understand some saws require massive amounts of work and some very little but does a cut base and popup really justify $200-300? Is that fair to your customers charging full boat for a job that could be done at home by most guys that have a local machine shop.
Nope. A cut squish and grind job on the uppers will net you the same effect but a tick more compression.Does it need a popup, or can you just cut the squish. I'm talking about a 550/545.
So I'd think it's a matter of perspective eh?
Is a person paying for chrome? Or performance gains?
listen guys...i didnt post this for a mob mentality attack...it is a learning thing for me and everyone else involved
So i had a saw cross my bench this week and it got me thinking....at what point do you get what you paid for with porting?
were the carb and bearing covered by the factory warranty? technically the factory warranty on this saw was void the minute it was modified. maybe clarification on what the word "warranty" is meaning in this case. are we considering the "warranty" being handled by the builder out of his pocket? or the factory taking care of the warranty. if the ladder is true, and the factory is handling the warranty, its possible that the builder/dealer got the lower end rebuild and carb covered by the factory...but there is no way a factory would warranty that cylinder as it has obviously had work done to it. no comment on the amount of work...I don't know enough about porting chainsaw engines.So if the carb and bearings are covered, why isnt the cylinder also covered
I heard ported saws were a fad , and loud , and smelled funny .....LOLI think this is turning into a great discussion.
Thank you all for being respectful to each other.
I can breathe a little freer........
Wise men have told me at times that less is more , they were right a few times..
The jug and piston had been machined, and therefore a dealer could not send it back to the factory if called upon to do so. The carb and crank could.were the carb and bearing covered by the factory warranty? technically the factory warranty on this saw was void the minute it was modified. maybe clarification on what the word "warranty" is meaning in this case. are we considering the "warranty" being handled by the builder out of his pocket? or the factory taking care of the warranty. if the ladder is true, and the factory is handling the warranty, its possible that the builder/dealer got the lower end rebuild and carb covered by the factory...but there is no way a factory would warranty that cylinder as it has obviously had work done to it. no comment on the amount of work...I don't know enough about porting chainsaw engines.
As a potential customer for some saw porting, what do you guys recommend, some kind of contract (estimate) that explains in detail what modifications will be made?
What kind of measurable work will be done?
There are some consumers that want the "saw to scream" and I don't know how anyone can measure that.
Or do you just find the guy with the best reputation and just trust that the outcome will meet your expectations.
I have no agenda here, just want to learn.
Frank
no way of knowing that without the builder coming forward and telling how things went down. as far as the customer is concerned..it was covered by warranty from my understanding.were the carb and bearing covered by the factory warranty? technically the factory warranty on this saw was void the minute it was modified. maybe clarification on what the word "warranty" is meaning in this case. are we considering the "warranty" being handled by the builder out of his pocket? or the factory taking care of the warranty. if the ladder is true, and the factory is handling the warranty, its possible that the builder/dealer got the lower end rebuild and carb covered by the factory...but there is no way a factory would warranty that cylinder as it has obviously had work done to it. no comment on the amount of work...I don't know enough about porting chainsaw engines.
spend a few months reading posts, you will aquire a sense of what kind of saw and service different guys offerAs a potential customer for some saw porting, what do you guys recommend, some kind of contract (estimate) that explains in detail what modifications will be made?
Frank
yes I agree...was the crankshaft replaced as well? that's not really relevant...im just curious.The jug and piston had been machined, and therefore a dealer could not send it back to the factory if called upon to do so. The carb and crank could.
