fordf150
- 9:48 AM
- Jan 18, 2016
- Newcomerstown ,Ohio
So i had a saw cross my bench this week and it got me thinking....at what point do you get what you paid for with porting? I am no saw porter even though i have done lots of auto heads back in the day.
The saw showed up wanting traded off...to be honest, a like new ported saw wanting traded even up for a 6100 raised flags for me.
Step 1:
First step in determining if i would take it on trade involved hooking up and checking run time and fault codes.... 6 codes stored...3 of which are for air leaks, 1 for a faulty throttle function, 1 for a bad module, 1 for loose red wire. No wonder it doesnt run correctly and he wants to trade it off with it only showing 4 hrs.
Step 2:
Owner of said saw gives the history of the saw... and i basically said NO>>>no interest in this at all but why dont you let me tear into it and have a look. Promised to treat him right and do what i can to get him a reliable saw without breaking the bank considering the money he already has invested.
Step 3:
A test run just to see what the old girl does but first, lets do a pressure and vac test and compression test.
Compression was a miserable 160psi
Pressure test failed miserably, it required constant pumping to maintain 7psi...In just a couple minutes we found the base gasket/transfer cover leaking.
Step 4: forget about a test run and just tear the stupid thing down and fix some air leaks. Here is what i found. What do you all think of this. The following is what caught my attention first.
Step 1:
Step 2:
Step 3:
