RIDE-RED 350r
- 5:18 PM
- Feb 8, 2016
- Blossvale NY
How would it pull without it? The escaping gases burn the oxygen and created a very strong vacuum. Something has to fill the void.
Maybe I'm not picking up what you are putting down Jim, but combustion itself, the force that drives the piston downward is rapid expansion, a near instantaneous and massive increase in pressure. That expansion pressure is why we need a certain amount of blowdown, to allow that pressure to be vented out the exhaust enough to allow the transfer charge that is being pushed up from the case by the downward movement of the piston to enter the combustion chamber. That pressure wave is what a tuned expansion chamber pipe utilizes to "stuff" some of the transfer charge that escapes out the exhaust back into the cylinder. I still don't see a vacuum above the piston playing a part, or existing for that matter. In my mind, the only vacuum generated or pulling action that takes place in the entire 2-stroke run cycle is in the crankcase through the intake port. From there it seems to me that everything is pushed, by pressure.
