- 12:28 AM
- Jan 24, 2018
- Extreme Southeast CA
I can make it a little prettier if you'd like.
That’ll work great, Monte.
Thank god you didn’t attempt to weld it
Got a picture of the tach? I had one of the cheap ones gifted to me and it also read 17K. I knew better so I threw it in the trashI took it out and put it in some wood and tuned the top end by ear. I limbed and bucked a 10" DBH Wild Cherry that had blown into the upper pasture making sure not to keep it pegged more that 3-4 seconds at a time. I like to break them in gently like that. It is an absolute blast to cut with it, and that was still the 2nd tank of gas...
Being a total novice to this porting stuff, I thought I better check it with the cheapo tach I have so I went over to the neighbor that I cut wood with a lot since I don't have 3 hands to check this easily. He revved it up while I held the tach and the tach went right up to almost 18,000 rpm. That scared me and I thought what a POS cheapo tach so we did it again and it went a little over 18,000 rpm. That scared me enough that I grabbed the tweaker an gave it a quarter turn out on the high jet. It was getting dark so I put the saw back in the truck and figured I would ask you guys if I'm seeing things or what??? I'll play with it some more tomorrow and check it again.
So is 18,000 rpm even a for real thing on a chainsaw or do I need to throw away that POS tach and trust my ears. It sounded great while cutting. 4 stroking till it got into the wood with about 4-6" of bar buried and it would clean right up and scream. Even sinking the single dog and pulling on it didn't slow it down much. Like I said, I'm a rookie at this porting stuff and really liking to learn, but I'm having trouble wrapping my head around that many RPM without a grenade in my face.
Is my tach a complete POS or did I just step through the twilight zone into the world of pro series ported saws? I need to know. 18K???
PS... I will be using the little blue magic starting button on the side of the cylinder. I forgot once and it hurt a little bit...
Mine has never seen that much rpm. Maybe mid to low 15’s. Dumb question, is it still 4 strokin at 18? My ec346 would a little over 16.
