- 1:22 PM
- Dec 3, 2015
- Banner Springs Tennessee
Think I'll STFU now...feel like I'm asking too many questions
No. Ask more questions.
Why you not rent pigs?Ask more questions.
Turd polisher?It's an industry nickname for people who do Computational Fluid Dynamics work. I'm sure they also have misnomer for my realm of work.
The way I'm looking at it, the velocity through the transfers is more so coming from a negative pressure vacuum and with that source being so close the turbulence characteristics are not quite the same as general air flow. I think this is why the carb and intake play such a huge role in transfer size
So it's not the piston coming down and compressing the mix in the case to give the velocity? It's vacuum?The way I'm looking at it, the velocity through the transfers is more so coming from a negative pressure vacuum and with that source being so close the turbulence characteristics are not quite the same as general air flow. I think this is why the carb and intake play such a huge role in transfer size and shape.
When you blow a pressurized stream of air it builds its own momentum and will continue until laws of motion play their role to slow it down, which in a two stroke would blow the entire fresh charge right out the exhaust regardless of soundwaves. When you vacuum that same volume of air the momentum doesn't occur and the air flow stops the instant the pressure equalizes. And allows the soundwaves to work.
Turd polisher?
Metal Jockey?
At high rpm. I think the down stroke compression plays more into making a break between each charge to prevent flood limiting.So it's not the piston coming down and compressing the mix in the case to give the velocity? It's vacuum?
Hence the term "scavenging".So it's not the piston coming down and compressing the mix in the case to give the velocity? It's vacuum?
How would it pull without it? The escaping gases burn the oxygen and created a very strong vacuum. Something has to fill the void.With the exhaust port open, how would vacuum build above the piston to pull the transfer charge into the chamber?
It was mentioned in thread 1 that exhaust port timing had a relationship to the amount of cc's displaced. Does the amount blow down have this same corelation? I've heard the number of twenty degrees thrown around in the past. Is that a generic number like .020" squish band clearance? Which I believe, really is wrong for every size engine as well.
Isn't it also time for thread number four to come along?
