FergusonTO35
- 10:00 AM
- Jul 9, 2017
- Boonesborough, KY
Thanks Larry. Yep, replaced many of those over the years!
Now I know where to stop for gas in Virginia.View attachment 172563 View attachment 172564 View attachment 172565 The electric does not feed the fuel tanks. All the fuel tanks are 12 volt.
That's a lot of gas just for chainsaws. I am paying g over $3 a gallon for E free gas. Nice to meet a wealthy person.
I had a eu3000 motor bored and it smokes like a freight train. The machine shop fudged up the bore, can't remember the clearance but it was oversize. Ended up buying a standard gx200 as a replacement for that one.I picked up a EU6500 that had 131 hours on it. Hard to start and would not pull a full load once running. Figured it was the normal gummed up carb from sitting. The engine also had more noise from the valve train than normal and a knock that is typical from a 13hp Honda. Sooo. first cleaned the carb and go it so it would run but it still was not right and didn't like the noise. Pulled the engine out and replaced the cam and lifters. Checked everything and it all measured within Honda's service limits and looked good except for a little wear on the crank 0.0005 nothing out of the ordinary on a small engine rod was out 0.001 but with in spec. So I honed it and put new rings in it. Went to install the head and here is where the fun starts. Exhaust valve, seat and guide are junk. Then I find out the unit had been ran on propane and that is very hard on a engine that does not have the valve train set up for it. It also explains why the exhaust valve guide is junk. I have a very good source for parts so I replaced the head and installed new valves and keepers. Good to go, right? Started the unit up, fired up immediately and ran perfect. So I put it under a partial load and then full load after 20 min or so. Ran great except for on little problem still had a slight knock when fully warmed up. So me being the perfectionist I am would not be able to live with that. So apart it came again. I replaced everything rod,crank,piston,rings and all bearings. I put a .25mm oversize piston it in, I have most engine building tools so taking .010 out of a cylinder is no big issue but to my surprise Honda spec for piston clearance is 0.0006 to 0.0015 [that is not a misprint] I have built a bunch of engines but never had one with a piston that tight. I could not do the 0.0006 so I set it at 0.001, right at the middle of spec. Check ring end gap, rod and crank spec ect and reassembled. Unit now runs as it should, quiet and will put out 6500w + until it kicks out on overload. I now know why honda small engines last so long and do not need a oil filter. With tolerances like that there is not much wear material after break in to worry about. These generators are built very well. Everything on them is top quality and overbuilt. I can understand why they cost what they do. I have 2 EU2200's and sold one of the original ones that was 15 years old and still ran great with the original spark plug! There is not much out there that can compare. The Yamaha's are very close but that is it. CJ
The inverter generators use the flywheel side of the crank so no need for the swap, which is nice. Strip the motor down to bare bones, remove the governor, cut the output shaft off and slap it in. It was actually cheaper than rebuilding the original motor.Hard to find a good shop anymore, main reason I do what I can myself. Honda uses a crome top ring and they need a very fine finish along with the oil control rings. If I would not have had the parts into it already I would have just picked up a gx390 long block and put a generator crank in it. Cj
Howdy, i can't say as I have never seen a.bad one. My 15+ year old one still ran like new when I sold it. Still does (buddie has it) with the original spark plug. I believe the engine is a gx100 or 120. Popular in compactors. CjIve got the EU2.0I here downunder as my back up
We run 240 volt here , its only about 4 yrs old , love the ECO THROTTLE
there $1900AU so a bit dear but then down here you get what you pay for
Now if the engine stuffs up , is it cheap to buy another engine
PeterView attachment 178054 View attachment 178055
Yep has the GX100 engine , great when only takes 1 pull to start it , mine be lucky if its do 40hrsHowdy, i can't say as I have never seen a.bad one. My 15+ year old one still ran like new when I sold it. Still does (buddie has it) with the original spark plug. I believe the engine is a gx100 or 120. Popular in compactors. Cj
The new 2200 have the 120, I remember now. The front led will flash 1-5 depending on the hours on the unit. 1 is 100 2 is 200 and so on. They last a long time if the oil is kept changed. CjYep has the GX100 engine , great when only takes 1 pull to start it , mine be lucky if its do 40hrs
Peter
Thanks for the heads up.If you pull the carb to take it apart you need to take the high speed mixture screw out then use a flat blade screwdriver to remove the fuel tube then take the 4 screws out to split the carb. Also check the throttle shaft for wear. That carb is notorious for the holes hogging out.
