HELP! Champion Generator Model 41332 Will Only Start with Pull Rope
oldcoot
OPE Member
1:49 PM
virginia
My generator starts fine with pull rope. Starter won't turn over when using remote key fob or manual start switch on the side of the generator. Battery is fully charged. Oil level is OK. Makes a rapid clicking noise when I try to start (except with pull rope). Sounds like the starter solenoid might be stuck?? Is there a way to bypass the solenoid and try to turn over the starter itself to see if the starter is good?? Thanks.
maisl
1:49 PM
NH
Almost always - that's due to a failed battery or very poor connection between it & the starter relay.
The voltage starts out high enough to operate the starter relay (let's say 6V+), but drops below that when connected to the starter motor - releasing the relay, which allows the voltage to rise - so it's over 6V & the relay operates again... then immediately releases because the voltage drops
all that happens several times a second - leading to a "rapid clicking noise"
oldcoot
OPE Member
1:49 PM
virginia
My battery charger (Battery Tender) says the battery is fully charged. I connected jumpers from my riding mower to the generator battery and it started up right away. Looks like I might have a bad connection somewhere, or my battery charger is giving me false info. I'll be checking tomorrow. Thanks for your reply!
maisl
1:49 PM
NH
Very likely; dud batteries can appear ok on charging - yet fail completely under heavy load.
oldcoot
OPE Member
1:49 PM
virginia
You are correct! Connected riding mower battery and it started right up. Thanks !
maisl
1:49 PM
NH
My pleasure - thank you for letting us know how it worked out.
