psuiewalsh
Basement Bodging
- 11:15 AM
- Dec 23, 2015
- Nottingham,pa
Is the carb check valve leaking?
There is a nice upgrade for this chassis, you can use a clutch cover from a 455/460 and have a much nicer and easier to use chain tensioner. Shown is a 359 but the procedure is almost exactly the same for the smaller saws.
Remove the old cover.
Spin the clutch off, left hand thread.
Remove the drum and wind the worm gear out.
Here is the only difference in procedure. The 357/359 has two screws that hold the bar pad plate on, the smaller saws only have the one close to the bar studs.
It needs to be removed to access the old tensioner
Remove the old tensioner and discard it.
Reinstall the bar pad plate and wind the worm gear in.
Drop the needle bearing and clutch drum back on.
Grease the bearing.
And spin the clutch back on.
Awesome post and description, thanks Joe!
Clutch cover from a 455.
Much more user friendly tensioner setup.
And done.
I thought that riser piece wasn’t needed on a 350 to 346 conversion?The 346 cylinder draws pulse signal from a different place than the 350 cylinders. In order for it to work the bearing cup has to be modified.
346 cylinder, notice the pulse passage in the center on the top.
Stock bearing holder, if you just bolt the cylinder down your carb will get no signal.
Modified bearing holder, all that is really necessary is to grind in the notch in the center. But while you have the burrs out anyways...
I get Nachi and SKF on ebay for $4-$6 each. OEM seals are $8-$10 at my dealer. That's the route im comfortable going.
