What is the proper way to run a rim sprocket on the 350 I bought the drum kit and oiler worm for a 346. The crank is larger od on the 346 where the worm rides. It is sloppy on the 350. Is there a bushing? I have the spur oiler worm on it now but it is not a tight fit to the drum ribs.
Me tooI have been running the setup on my 350 for a while and it seems to work fine even though it's sloppy
So my question is how to turn my 350 into the 346xpTrying again with a problem child 350. I have had issues with sealing the case and bearing cup. Just installed new bearings and seals tonight. Will P&V tomorrow evening.
Ive got 345 saw alsoSo my question is how to turn my 350 into the 346xp
Sent from my VS425PP using Tapatalk
346 piston and cylinder.So my question is how to turn my 350 into the 346xp
That one needs the 350 bearing cap then the 346 piston and cylinder.Ive got 345 saw also
Cool thanks and that will make them better imThat one needs the 350 bearing cap then the 346 piston and cylinder.
you need to buy the worm gear for the 350 Keith.What is the proper way to run a rim sprocket on the 350 I bought the drum kit and oiler worm for a 346. The crank is larger od on the 346 where the worm rides. It is sloppy on the 350. Is there a bushing? I have the spur oiler worm on it now but it is not a tight fit to the drum ribs.
Looking for some assistance. I put a 346xp, OEM, p/c on my 2007 353. Same time I change the rubber/plastic from the carb to the port inlet.
I can't get this thing to idle. Right now I have adjustment all the way closed and it works best like that, but I still have to feather the throttle to keep it running, until good and hot. Any adjustment to the right and the saw will die quicker. Was there an ignition or carb change I should have made too?
Pulse line have a hole in it, or possibly pinched?
