- 11:25 PM
- Jan 8, 2016
- Mandal, Norway
You never needed to split the case anyway to exchange the valve, but its not easy.
Here is what I would do:
Turn the saw so chainside is down, use air pistol and blast around the opening to the valve, you should be able to see the oil bubbles through the oil refil hole. There should be no oil going out the other way.
If you though have to exchange an oil valve later, if you study link I provide earlier you can see that the valve has 3 different dimensions, but the crankcase doesnt have 3 dimensions, only 2 on my 346. The dimension in crankcase is around 6.5mm, and it goes 15mm deep, but the valve itself has only 7.5mm lenght that has 6.5mm.
So in general it should be possible to drill with an 6mm around 10mm deep, there should be little resistance left and should be easy to knock out the valve through the oil plug hole.
Dont know if all this make sense though lol
