- 6:32 AM
- Dec 26, 2015
- The land of pleasant living
Ok guys and gals, need some help with this 242 before it becomes something to sight in my 30-06. Heres the story..bought it for $25 on fleabay, bid on it not dreaming I'd be the only one. Everybody else was smart evidently. It was missing some smalls and a little bit faded but mostly complete. Got it here, it had 140# of compression. Replaced fuel line, fuel filter, rebuilt carb, pressure and vac tested, and got the smalls. It wouldnt run right, kept stalling out when I'd throttle it up and let off the throttle, didnt matter where I had the carb set at. Bought another carb thinking that it might be a carb problem, no change. So, I bought another set of electronics, and that solved the dying problem but could only get up to 13.5 then gradually after 5-10 secs would go to 15.3. Idles perfect, throttles up fine, but cant get it up to speed on initial throttle up. Doesnt have a muffler screen to be clogged. Air filter and pre filter are good. Changed spark plug and fuel filter twice. Talking to a member he suggested a new metering spring. Installed brand new metering spring and set lever and still no change. Bearings are good. So I'm stuck because I dont want to just throw money at this f##ker. Anybody have any ideas that might make this saw run the way it should?
