- 5:15 AM
- Mar 13, 2023
- Maryland, USA
So we have two ms 201's. Both have timing advances and muffler mods. 1 I ported. Both keep stalling. The one that's not ported, started stalling shortly after the timing advance. I advanced both 7*. They run great (especially the ported saw) on throttle. But they will not idle. I've been through the carb on the non ported saw. I found debris and rebuilt it, replaced filter, lines, and cleaned tank. The ported saw is currently running on my fuel, which is new, 40:1 hp2 87 octane. My can is rarely on the job so it's insulated from the debris and abuse our companies cans are subjected to. The house fuel is 50:1 shiot 87* stens oil. Both saws have been pressure/vac tested and only the usual throttle shaft weaping was found... All you blokes have more experience than I... So, I'm reaching out for darts to be thrown my way. Thanks! (I have a theory I should undo timing advance as a test)
