I really don't understand this 346 clutch side bearing/seal issue, I was nerveous the first time I swapped bearing but I followed the advise to Randy and it turned out to be easy.
Freezer and heat is vital on 346 clutch side bearing.
This bearing/seal is the same Husky continued to use on 545/550/555/560/562/570/575.
Reason why they use this sort bearing is to shave off the crank, ie, more slim body, something they started to do back in 1980 with their 133 model who has one expensive PTO bearing from slacker, and they continued to use this slim design on 242, and they took it even further with 550, that crank is so compact that its almost scaring!
I for sure like the price tag on traditional system where bearing and seal where seperated, but when I go for firewood work I love those slim Huskies.
