Devil With A Blue Dress.....:)
stihl_head1982
Here long time
12:38 AM
USA
Over 2,700 views so far. It appears this review is quite better than the kit saws reviews. Thanks Walt, I've come to admire your insight and your willingness to post your findings.
smokey7
12:38 AM
Detroit
Wonder if they really do have different grade parts??? If the prebuilt saw has functional parts where we normally had trouble maybe thats the case?
00wyk
5:38 AM
Ireland
How is it after a month or so of use? I got a bud interested in one. I tried to talk them out of it. It is €300 to our door here in Ireland...
I Know Something
11:38 PM
Fairmont, Minnesota
I ordered mine today. Its arriving as a kit. I need a bigger saw for a lot of big oak and maple from a September wind storm we had here. I will be moding it. But, not till next year. I did order the big bore kit and the wrap handle. This thing is going to get worked. A lot. I'm expecting parts to fail and it not make it threw the spring/summer/fall in one piece. But, I need this tool. So. Here we go!
12:38 AM
Replace the piston pin bearing with OEM, and the rings with Caber, and spray some WD 40 on the rest of the bearings as soon as you get them to flush any grit out, and it should last you a long time.
I also use an OEM Elastostart pull cord.
Funky sawman
Pony Power
9:38 PM
North idaho
This particular saw wore stihl color. My point is that all these clones that i have worked on have the flywheel built in the same manner. All aluminum and a magnet with a cast iron or sintered center hub, instead of using a machined steel hub like stihl uses. This seems like a huge safety issue. This Isnt the first clone i have seen with flywheel hub and or key issues
afleetcommand
12:38 AM
CNY
Certainly something that has worried me with the desire to mod saws up to higher RPM. Saws of any color BTW; but just curious why would a cast hub vs machined hub matter vs. the actual aluminum melt chemistry? I would be way more nervous about things like porosity and the quality of the casting. To this point I haven't seen any failures but there is always a first time. Be curious if you have some close ups of that flywheel, especially around where the fractures were. Also if you have seen a few, pics of those so we could see or identify a trend or a cause.
Funky sawman
Pony Power
9:38 PM
North idaho
What i think most likely happened with that split flywheel is that the nut was overtightened and split the hub, then flywheel came loose and hammered on the key, which i did see damage to keyway cut into crank. The hub on this flywheel seemed to have very course grain and was quite brittle. Almost like it was made with sintered bronze, but it was magnetic.
Funky sawman
Pony Power
9:38 PM
North idaho
Funniest part about the whole deal was the customer insisted that his saw was really a genuine stihl product. I showed him were the serial number was supposed to be and it was just a blank spot
12:38 AM
I have not had any issues with the AM flywheels, other than one or two that spun the first time due to poor fitment on the crank.
IIRC, the center seems to be steel, bonded to aluminum (or similar). I have built numerous 660s and 440 BB or Hybrids w/o any issues.
67L36Driver
11:38 PM
Sucks that i didnt get any picts of it. I just reciently got a smart phone after having a old flip phone forever. The old phone didnt take picts, and it takes me a bit to think that "hey i have a camera to use!"
After the get acquainted period you will use it more for the camera than actual telephone calls. [emoji2960]
