- 10:09 AM
- Dec 3, 2015
- Banner Springs Tennessee
Maybe it wasn't his thumb???
Oh hell.
I welded my John boat back together with those and an oxy/acetylene torch. It worked, but was hard on thinner aluminum.I have had good luck with alumiweld rods. It more of brazing stick, but I used it to fix a cracked aluminum lid on a Weber grill.
Just get the part hot in the oven first then use a mapp gas torch and it goes on like solder and flows well. It’s pretty strong. It held the grill lid together fine.
Harbor freight has it
https://m.harborfreight.com/8-piece-low-temperature-aluminum-welding-rods-44810.html
Will a wah wah pedal hooked to my tractor battery work?
Lol this took a major left turn.
Apparently it’s not a hard as it looks...
[emoji41]
That looks like expert work with a tig, (just sayin)
Horry SheetI want to weld this so it doesn’t break off. I have a stick welder. Can I make it work?
Dont drink the Kool AidAny tips?
Meh .............. mayhapsHere is a video rite from the interwebz
So it has to be true.
ROFLMAOAfter I learn I’m gonna fix this one
IndeedBoy that looks familiar
I've given a few Dutch ovens before, NEVER came out that goodMan, I don't know. I haven't stick welded cast aluminum. Only sheet. I welded a Dutch oven a couple years back and I just stuck it in the oven on self clean setting, high heat for a while and managed to weld it without it cracking.
IncredibleView attachment 115381
Looks like this one...
Like when you do a guy a favor for a saw he's keepin and definitely not selling. Then he flips anyway
You trolling dudz again ?Hey cuz...
LuckyWow! Came. Out better than I thought it would!
DoubtfullI think I can make it look better than that.
What'd she say ?I gave the wife a Dutch oven this morning.
No way, it was definately that foilI wasn’t sure the aluminum foil would work, maybe it was the coat hanger that helped conduct electricity
I'm callin BS ............ whats Bradleys number again ?Gotta work with what you’ve got.
Good enough for who it’s for?
Me tooI wish I had a welder...
Whaddya you know ??That looks like expert work with a tig, (just sayin)
Holding a patient like a bowling ball may be "alternative" medicine in Tennessee...That doctor needed some sort of thumb control.
