- 2:05 AM
- Jan 24, 2018
- Extreme Southeast CA
24” small mount. @SOS Ridgerider @Cat 525
Normally probably wouldn’t be economically viable.
And I didn’t bother heat treating it and all that like it should be.
Maybe if one just shortened it by cutting out the bent sections to the next size shorter you could do it fast enough to be viable. The straightening and opening the grooves was tedious. I expect a bar shop with the tools n tricks handy could do it better and faster.
I got it bound in a horizontal tree in a tangled mess of trees. I knew better and shouldn't have tried to cut it. I removed the Dolmar from the bar. Should have wedged it loose, but I was distracted. When I cut it loose with the 2166, it fell perfectly across the Vee of two other trees below and the one that I cut loose went right in the middle of them/the bar. Bent 90 for 30 secs and then snap! Should have had my buddy come hang onto the bar while I cut it loose, but I didn’t want to ask him to climb up there, and I didn’t think it would fall perfectly under the log...
Rubber backer to bang on, soft mallets/alum punch. Brass channel fillers for welding and steel for straightening.
Cleaned the channel out with a hacksaw blade and emery cloth.
