- 4:57 AM
- Dec 29, 2015
- Strong Island NY
Gregg,
That jug should clean up easily. Get some muraitc acid and some fine sandpaper. Just gotta be careful and have a bucket of water with baking soda dissolved in it close by.
Degrease the transfer area, sand lightly, add acid with Qtip. Rinse, resand lighlty, add more acid. Do this till the is no fizzing.
You just don’t wanna get acid under the plating as it will undermine it. Be careful by port edges. If you see an area that won’t stop fizzing, you’ve got a pit in the plating. Neutralize immediately.
When you’ve got 99% done, sand the bore with 320 sandpaper, then hone with WD40 and scotchbrite. You’ll be back in bidness.
