Lightning Performance
- 12:18 PM
- Jan 26, 2016
- East of Philly
@drf256View attachment 113236
These are timed roughly the same in a Stihl 460 cylinder.
Which one traps more volume under it at intake floor closing?
Will that make any difference when the difference in volume will be the same at int close - volume at BDC?
The upper is open for longer under the piston lands on the single ring piston. So there’s more time for the tunnel to fill/mix through the upper and lower during induction cycle.
Does any of it matter?
Were the two 036/360s you built, I ran, at the TNgtg set up with single or double ring pistons?
