- 12:58 AM
- Oct 18, 2016
- GFY
Well the 330 is a back up for you now.Busy as all get out!!! I did manage to pickup a 355t though beginning of the week!
That's too high for a x torq.13000 max I had set mine to 12900New guy here!
I’ve got a two year old xtorq that does the same thing as the OP. I’ve replaced the coil ( with an oe limited) which solved my startup muffler detonation problem. I’ve tinkered with the carb adjustments to where it sounds good. How lean is too lean on the top end? If you guys are suggesting that’s possibly the trouble. I’ve put the tach on it and tuned high side to 13,100 or so.
Welcome to the siteNew guy here!
That’s what I was told too! It seems to run fat at those speeds though. It starts right up idles great and runs out great as it’s tuned just dies instantly once you lift off the throttle when finishing a cut. Then one pull and fires right back up! If I move the L screw any it has no throttle response and on the high side I’d hate to lean it any more.That's too high for a x torq.13000 max I had set mine to 12900
Sent from my Pixel 2 XL using Tapatalk
Sell it to meThat’s what I was told too! It seems to run fat at those speeds though. It starts right up idles great and runs out great as it’s tuned just dies instantly once you lift off the throttle when finishing a cut. Then one pull and fires right back up! If I move the L screw any it has no throttle response and on the high side I’d hate to lean it any more.
Been there done that.i know what you mean.only way around it is to set the idle little high like maybe 3000.or cut the the divider out if the intake boot.what happens is after full throttle there's excess fuel in that intake boot and you left off the throttle it gets to rich and quits.start it up once and let it idle a minute.then with the saw sitting on the ground idling pick the handle up so the bar is pointing at the ground straight up.i bet the idle starts to go down.That’s what I was told too! It seems to run fat at those speeds though. It starts right up idles great and runs out great as it’s tuned just dies instantly once you lift off the throttle when finishing a cut. Then one pull and fires right back up! If I move the L screw any it has no throttle response and on the high side I’d hate to lean it any more.
Wouldn’t taking the plastic divider out of the rwj do the same thing as gutting the entire intake tract but a lot less work?
