- 8:50 AM
- Jan 1, 2016
- Warren Center, PA
Is the washer that the oil pump gear rides on in place? I'd like to see a picture of the carnage...
Probably just a superceded part number.Also, why does the IPL give me two different part numbers for the same crank sleeve?
503 77 91-01
503 96 70-01
Or, if there is a difference, what are they? I cannot tell....
I wish! I haven't had a chance to even run the saw yet! I bought it as a non-working unit and have slowly been picking away at it.That fugger was hot!!! Dull chain?
In the same book? Interesting...Probably just a superceded part number.
Lemme check my book...In the same book? Interesting...
Yessir...lol.Aaand, I'm an idiot. The other is a bushing for the chain brake handle :/
The return spring on the carb goes into a hole. This hole can sometimes start sucking in air. Hell knows how but I have had two oe 372xp carbs do this. I pull the spring, put some jb weld or similar and then put the spring back in. Seems to fix the erratic idle issues on the two I’ve had. Seems like a wild shot but worth checking. Basically the hole leaks in and around the check ball on the choke flap.
