Chainsaw Jim
Con Artist LLC
- 1:14 PM
- Feb 8, 2016
- Springfield Oregon
Wouldn't racing speeds benefit from less time circulating in the case?Leaving the crank stuffers in? I wonder if the case volume will limit your power at racing speeds. I’m very curious how this one turns out.
Could this be done on a 359 chassis with a 365 cylinder?Wouldn't racing speeds benefit from less time circulating in the case?
I know it won't be good on bearings at those speeds, so bottle priming enough to wet them really good will be necessary.
This one in the video has the stuffers in place. Would you consider it anywhere near racing speed? It seems to have comparable strength to anything I've ever ran under 80cc's, but I am disappointed that I didn't grab another 70cc saw to compare with that day.
Removing the stuffer cups would basically make this chassis a 359, but the 365/372 cylinder is too wide at the base to make fit.Could this be done on a 359 chassis with a 365 cylinder?
Gotcha thanksRemoving the stuffer cups would basically make this chassis a 359, but the 365/372 cylinder is too wide at the base to make fit.
But it could be done with a 359 and 272 cylinder? Correct?Removing the stuffer cups would basically make this chassis a 359, but the 365/372 cylinder is too wide at the base to make fit.
YesBut it could be done with a 359 and 272 cylinder? Correct?
Tough to really tell without seeing it in some square wood where you can really time the cuts from saw to saw. Looks like it runs good!Wouldn't racing speeds benefit from less time circulating in the case?
