346NE vs 254XP vs 55CP...Sibling Rivalry. Results are in!!!!
RIDE-RED 350r
4:32 AM
Blossvale NY
I always thought the 362xp was simply a 372 bottom end with a smaller top end and small mount setup?? Seems like it would be considered underpowered for it's weight and handling?? It was 62cc actual displacement, correct?
4:32 AM
That’s exactly what it is
dustinwilt68
Wilt Built Work Saws
4:32 AM
Southwest PA
362 and 2163 are all small mount as far as I know, 365 and 2165 are large mount. My 2163 now has a brand new ported 365 special top end on it, 65cc is the top of the 4 cube class, @rattler and I ported mine in January, we set the numbers for a 20" bar, runs amazing so far, plan on it being my main saw this spring to break it in.
Onan18
OPE Sponsor
4:32 AM
Georgia
The 362s were all small mount, same crank as a 365/372, different top end. Only 62cc and a dual port but they are snappy, a stock 362 turns 1000 - 1500 RPM more than a 365.
XP_Slinger
They’re Just Saws
4:32 AM
Central NY
I think what @XP_Slinger and @RIDE-RED 350r are forgetting is the FACT that the “Squatched 55” is gunna make em both cry and make them wish they hadn’t “messed with Sasquatch”. Debate over. :campeon:
Unless you grab my 357 and put a 55 sticker on it you’ll be walking away a sad sad little puppy dog...lol!
Cut4fun
Redneck Chainsaw Repair
4:32 AM
Ohio
362xp was a small mount early and then went large mount later in the run. So there is 362 large mount saws later.
So not all 362 are small mounts. ;)
Yes you could put any top on them 362 365 372 etc.
I built one from 2 bare halves to just test one out.
cobey
3:32 AM
Pittsburg, kansas
Let me drag @cobey in here. He has some experience with both I think.
Stock a 254 seems to have more torque
I have a stock one that doesn't give anything up to at least one ported OE
But.... it' probably different with different saws.... both pretty cool, both winners in my book :)
Tor R
Newbie
10:32 AM
Mandal, Norway
254, year 87, OEM jug, thin ring piston, 0,4mm gasket, 020" squish, pretty much close to stock with a 0,5mm gasket, but those jugs had a very little compression chamber......
I like them just as much as I like 262's....maybe a tad more also.
Except those 4, there is two other Mahle out there, and one KS with decomp:
The one who gives this insane compression is stamped the same as the one left bottom, 86.
XP_Slinger
They’re Just Saws
4:32 AM
Central NY
Great info as usual Tor thanks for sharing! I’ll have to look back in my 254 build thread, pretty sure it has a Mahle cylinder but I don’t know what stamp it has. I tried no gasket in it but as I expected it was a head slapper so no go. If I can’t find good enough pics of the cylinder I’ll take a look at my Saw tomorrow. I do know that it pumps up to about 175psi. That is if my memory serves me...usually doesn’t lol
