Thumper88
- 1:19 PM
- Feb 28, 2020
- Harriman, TN
Alright guys, I’ve got an 066 in a box courtesy of a member here. Trying to figure out what I’ve got and what I need for a good stout build. I’ve got two sets of case with cranks. Both cranks are shot, the rod bearings are shot. One has an aluminum flywheel and one has a poly. I have one new crank assembly that was included separately for the poly flywheel saw. Have a WJ69 carb. One tank assembly with wiring and carb boot. Top cover, clutch cover, brake flag, brake parts, clutch assembly and some odds and ends.
I plan on doing a full build and here’s e parts list I have so far. Any help is appreciated, I’ve never done a full build before. I’m hoping to find someone local to Knoxville who can help me setup the bottom end.
Parts list
Full gasket kit
Crank bearings
Crank seals
New HO oil pump assembly
Piston and cylinder kit
Unlimited coil
Max flo air filter
what parts am I missing and any tips, tricks or help for the newbie?
Parts list
Full gasket kit
Crank bearings
Crank seals
Unlimited coil
Max flo air filter
