stumpyfine
- 12:51 AM
- Feb 13, 2017
- Cambridge New Zealand
Feeding a piece of rope about a foot into the cylinder through the sparkplug is a good way to stop the piston allowing you to torque the flywheel nut of clutch. Just be sure to raise the piston so the exhaust port is covered prior to feeding the rope in.After checking with this site’s information and a friend of mine that does small engine repairs, this 660 does actually use a poly flywheel.
My buddy pulled out a brand spanking new 660 saw that he’s been using as a parts saw for when parts are needed quickly.
It was missing a flywheel too as it wasn’t replaced yet.
He pulled out a new flywheel from his stock and put it on. It moved a little bit like the taper doesn’t line up until he bumped it a bit onto the crank.
Then I started realizing that I wasn’t getting my 660’s flywheel tight enough as I was attempting to do it by hand and with a ratchet.
My shop battery impact tools were at work so I had nothing to use to tighten the flywheel nut.
I brought the small impact home that does around 35-40 ft/lbs. close enough.
After getting the flywheel tightened, I tried it on the dyno, it works. Did 2 long pulls, half a tank of gas with no issues.
So I think I’ve got it figured out.
I thought I was able to do 30 ft/lbs with just a ratchet and holding the wheel with my other hand as I did not want to use a screw driver to stop it from moving.
Listen to this man here. I use an impact to snug the wheel on, especially when rotating counter clockwise to confirm timing advance against the key. Then I rotate it the other way and use a torque wrench at 27 ft/lbs. I use rope in the chamber as a stop ALWAYS. Safest.Feeding a piece of rope about a foot into the cylinder through the sparkplug is a good way to stop the piston allowing you to torque the flywheel nut of clutch. Just be sure to raise the piston so the exhaust port is covered prior to feeding the rope in.
I’ll get some rope. I don’t have any.
Thank you guys.
I’m glad the saw runs again. I was going the wrong way with thinking there was another flywheel because I assumed a taper fit means there is no movement when test applied to the crank before the nut was installed.
