Dieselshawn
- 9:00 AM
- Feb 6, 2016
- Southern Ontario, canada
Hello fellas, I’ve got a 2013 MS660 that I’m trying to get running.
I was given a couple parts box of several MS660’s and 661’s from my logging buddies.
(they needed storage space in their shed)
They said I can put a 660 and a 661 together if I wanted with the many parts in the spare parts boxes.
So I found a 660 in the box that doesn’t look like it needed much to get running.
Has a poly flywheel on it but wasn’t tight to the crank. Key was sheared.
I put a new key in and torqued it down. After 3 passes on the dyno, the saw shot a blue flame and shut down. I heard spinning noises. The flywheel came loose again.
While looking it over, the taper of the flywheel and crank doesn’t seem to match. It’s loose.
Here’s the serial number for the 660
175771283.
I’m told there’s maybe 2 different style of flywheels?
175771283.
