BonScott46
- 6:20 AM
- Jul 20, 2016
- Sweden
Maybe an 8 pin would help.
Thanks. Yeah, I'm pretty pleased with. Not bad considering I've not touched the ign. or the transfer duration. I'm guessing with those mods and slightly more aggressive inlet and exhaust timing, you could squeeze 15.5k out of one of these babies....That's a good tune. It still readily 4-strokes.
Yeah, I did ask about that a while back. Most people reckoned on 7 - before I got her running.Maybe an 8 pin would help.
Yeah, that's true. Reckon I should keep the 25" bar with the 8T too?I was thinking it might help put more load on the rings and help them seat.
I would but that is me.Yeah, that's true. Reckon I should keep the 25" bar with the 8T too?
Yeah, it's pretty tasty now!I like the beech cutting vid, where it goes VerrrrVeeerrrrr and Judders while it pulls like a train,
yeah the clutch losses grip at times but that's ripping for you.
I guess your happy with that saw,, I know I would be.
The tune in the first video sounds better than in the second video. The second one sounds a little on the lean side. Or, are you giving it partial throttle?A couple more vids. I messed with the carby in the week. Previously "I'd set the POP". I'm curious as whether that was such a great idea. Wondering if it made it harder for the saw to pull the needle off the seat at idle, because idle is hard to set smooth on this thing. Who knows? Anyway, I just (eventually) reset the inlet lever thing back at 0.8mm. I've retuned it a bit, I think it tachs to about 15-15.2k. Definitely as high as I want to go with, and reckon that when it goes in much bigger wood, then perhaps it should be made a tiny bit richer. Thoughts?
and
I guess the idle is better now have homed in on the tune more and it's loosened up a lil. The trigger response is ace, and the hot restarts are 1-pull. The chain ain't creeping yet, but probably because the clutch is brand new.15k- I’d go below that for actual saw work... but that’s just me.
Did the idle issue go away? Lots of factors affect idling, so just set it for a steady-ish idle close to spec where the clutch doesn’t engage. And of course look for good throttle response and 1-pull restarts when hot.
In the noodle vid I've exactly the same H screw setting as the first vid. (Hmm... I may have twiddled with the L side..). But yeah, I will have definitely started cutting on partial throttle until buried and then whacked it on full.The tune in the first video sounds better than in the second video. The second one sounds a little on the lean side. Or, are you giving it partial throttle?
I know what you mean I often like to tach it after a screw adjust just to get a ball park idea of what's going on with it.Forget what the tach says and quit worrying about actual RPMs. Give the saw what it wants to run right.
I'm glad it's not just mine that's temperamental on the L tune! My experimentation with POP is over for me now. Probably more necessary on machines where the fuel is pumped, I'm only gonna pay strict attention to the lever height being in spec from now on.I tend to chase the L tune on my 440/460 hybrid as well. I have never messed with the POP on a saw, so don't know what affect that may or may not have.
Ha! Indeed.....personally I'd rather take the carbon anyway. I know you got carbon sucked back into yours, Wes, but when I got my 044 the top end had lean abuse written all over it. There's a couple of pics on the first few pages of thread, if I recall.A bit rich might add a bit of carbon to the exhaust. A bit lean might add a bit of aluminum(or aluminium) to the exhaust. Take your pick.
