Wt215 issues on 023
angusjones8
2:18 AM
Nsw
Had a 023 given to me with the carb disassembled, I grabbed a kit from stihl and am now trying to workout what order the gaskets and diaphragms go. I got it together how I think it goes and it runs but spits a *s-word load of fuel back out the carb.
Hope someone can help.
Thanks
walterg
2:18 AM
NC USA
I'm running a clone carb on my 021 with no issues. The OEM carbs are $30 or less.
I was short on cash so I went with the clone.
Sent from my LGLS770 using Tapatalk
angusjones8
2:18 AM
Nsw
just curious...
did you have a peek at the cyl through the muff yet ?
Sometimes its a bad ring that causes spitback...
Everything looks great through the exhaust port. I'll get some pics up tonight.
angelo c
Coal Member
2:18 AM
what sort of base settings are you at for HI-Low. try leaning the low in some...maybe just too rich.
Are you getting black sooty looking schputz coming from the muffler ?
Adirondackstihl
2:18 AM
Upstate NY
I'm betting the gaskets and diaphragms are out of order.
Metering Side:
Gasket against carb body then diaphragm
Pump side:
Diaphragm against carb body then gasket
OR
You should happen to get a POS carb
angusjones8
2:18 AM
Nsw
Pull the carb and take a gander down the intake port. See what your intake piston skirt looks like.
Bad ignition timing could do it also.
Ah I didn't think of that. I'll check the key when I get a chance.
angusjones8
2:18 AM
Nsw
Here are some picks of what I thought went in the carb and what came in the kit.
angusjones8
2:18 AM
Nsw
Also my favourite saws, my 026 and 036 I built, both rebuilt, thin or no base gaskets, opened up mufflers and they run great!
Also my other 026 with stihl/atom auger.
dougand3
1:18 AM
North Alabama
I think you need the blue pump diaphragm instead of the clear-ish one. See if blue flaps cover fuel holes in carb body.
Also, remove needle and clean it, make sure hole under needle is open.
angusjones8
2:18 AM
Nsw
Awesome. Thanks guys. Play with it through the week.
