Wicked 090
Deets066
AKA Deetsey
7:58 PM
I could Probly get a custom pin bearing that’s smaller so I have to bore it less.
mgr1
1:58 AM
Belgium
Bearing 15x18mm vs 13x17mm small end?
mgr1
1:58 AM
Belgium
That is a problem. No bearings in 15x17mm.
You need a custom conrod or custom piston.
Do You know the big end pin diameter and the conrod length from this 084?
Deets066
AKA Deetsey
7:58 PM
There’s only so many custom 70mm pistons.
I wonder if crank works could help me out
Red97
7:58 PM
MI
Make 2 reducer caps and run the 13mm pin in the 15mm piston hole.
Whittle Couple of bronze caps. should do the trick.
Bore the I'd to just fit the 13mm pin, turn the od to just fit the piston.
Same length as the pin boss for full support.
Fully closed/ or a hole in the end, depending on circlip style.
May have to shorten the 13mm pin a bit, but I would go that route before messing with the rod end.
mgr1
1:58 AM
Belgium
1mm reducer tickness with that rpm's and torque?
Red97
7:58 PM
MI
You want 1mil bdft?
Or to make a few dozen 3 cuts?
Some of the bronze will be harder than the aluminum...
I don't see it any different the bushing the small end of an auto rod, those are not much more than 1mm wall if that.
Red97
7:58 PM
MI
that might work, measure three times, lathe once
Find enough material to lathe 7 times..
As long as the 13mm pin is captured on the cir clip ends. That should be the only "problem" area. The 13mm pin sneaking out to tango with the circlip/ transfer port.
But a blind bore bushing would solve that.
Deets066
AKA Deetsey
7:58 PM
I do believe I could make that happen, I’ll see just how much bearing the 13mm pin will have on the piston and decide with my inadequate engineering skills if it will be enough to hold 157cc together running on nitro. Lol
Lightning Performance
7:58 PM
East of Philly
Use the bronze sintered bushings available.
Joes right about using bushings that look like cam buttons with holes punched in them... been there did that a long time ago to big bore a Yamaha dirt bike. Make them big so they fit the piston tight. Our first slide in set ruined the piston from slop.
Thought you were doing this from the start.
I used aluminum cam buttons to test fit mine. Had a local tool maker spin up the bushings in bronze. It worked great but it needs little play or beats up the wrist pin clip bore in the piston. We had to use driveshaft cup needle bearings and reamed the rod to fit. Fuggin runner to. It was like an MX 385 or something like that when finished. Wheelie machine. Stuck nitro in it to. My cuz damn near hit a pole with it on a hot shot so we gave up on nitro runs in the street.
Nice call on flattening the case top. 518 the plate.
It should go with a pipe :headbang:
Red97
7:58 PM
MI
I think it will work fine.
During teardown I would inspect the pin/bearing extra close...
It is a bit under the 25% piston to pin size ratio.. likely see a bit of deflection. But should have plenty of service life... Should
