why me? 372 blown...again
Mattyo
Youtube speciawist
11:10 AM
Farmington, CT
Hey....live and learn right?
Problem is...it's so easy to blame the material and just say it's junk....harder to blame the mechanic. I think case....I'm blaming the mechanic.
Cylinder cleaned up nice. Just needs a wash now and new piston.
Mattyo
Youtube speciawist
11:10 AM
Farmington, CT
saw is cleaned up... gonna cut a new popup as soon as the meteor piston comes out of USPS limbo. will pressure test and double check the tank vent.
Member
10:10 AM
Sounds like two wrongs couldn't make a right.
Is a good example of how quickly things can turn sour, even with our best efforts put forth.
Some times the difference between success and failure is checking it again even though you just did before.
If it were up to me, I put a non hardening sealer on the bushing to hedge my bets.
Good luck Matt, they say third time is a charm! :)
Mattyo
Youtube speciawist
11:10 AM
Farmington, CT
funny thing is the 044 doesn't have an o ring! same idea, no o ring. just relies on the pressure from the clutch. obviously I hadn't cinched down the clutch and/or the clutch wasn't capable of tightening properly against the bushing.
I know a lotta guys would put sealer in there, I dunno. seems like ya gotta get it out one day though lol. who knows.
gotta triple check my fuel lines and vent. I've modded the tank vent to vent into the airbox, so i'm gonna triple check that ...especially after brad mentioned it
11:10 AM
I don't think it was the line. I think it was the vac leak. But...I think the line was causing the stalling in the cuts. ...
Only one way to find out. Kink the line off again but run a 372 clutch. Then we'll all know
Better order another piston
