decableguy2000
Finally had a good day weather wise and a day away from work. Had a tree fall next to the road night before last and another dead oak to drop for Pop's fire wood. Fresh fuel and 40:1 oil mixed up the other day. Used in my blower no issues. Fuel and oil up the 346, fired up, warmed up, loaded in the loader and went down to cut the tree up that fell. Ran great for 10 min and quit, it would start back with 1 pull and as soon as you hit the throttle it would die. Back to the house and got out the 351 and it ran okay go figure. came back up to house and droop the oak with a 2071 that I just put a new top end on (wiped out due a bad crank seal). Started up and idled great, would rev up fine but after several long cuts it would die after you let off the throttle. I have come to the conclusion that chain saws hate me. both saws pressure and vacuum tested fine and have new carbs, new NGK plugs, same gas as blower, 371, 351. I'm thinking fuel related / carburetors. I didn't bring the big boys out today but they hate me as well.
