Where to spray the crap?
juttree
5:25 PM
Wallingford, Ct.
I'm looking for some ideas on how I can blow off all the crud on saws without having it go everywhere.
I normally blow the saws off at the shop without having to worry much about where all the oily sawdust goes but it's a pain in the neck to because I do most of my repairs in my basement. I'm tired of having to drive to the shop after grinding or more dismantling. So I brought a compressor home and now I'm trying to figure out how I can set up a spot to capture the crud. I was thinking something like a sandblast type of setup but I'm not sure that will work good because it will probably just swirl all the stuff around.
I know the easiest solution is to do the repairs at the shop but if I do them at home the wife can't complain that I'm never here.
panteliss
11:25 PM
Europe
I have a plexi glass box with a water presure conect , something like sand blasting lets say , so the dirty saw go inside the high presure hot water do perfectly the job and all the garbage go to the cloaca , the saw comes out like new just out of the box
juttree
5:25 PM
Wallingford, Ct.
That's a very good idea but then I would need to set up a drain and water system.
juttree
5:25 PM
Wallingford, Ct.
Why not just get a hose long enough to go outside. Do you have a walkout basement?
That was actually the original plan when I brought the compressor home but after a little more thought, I really don't have any good place to blow it because it would look like an oil slick every time it rained.
Simondo
10:25 PM
UK
Air line ..Big cardboard box ...free...use and burn or out for the trash.
Marshy
WFO Cutting
5:25 PM
Mexico NY
How many are you going to be blowing off? I doubt you'll see a sheen of oil on the grass if your only doing it once in a while.
Marshy
WFO Cutting
5:25 PM
Mexico NY
Good idea. Like a refridgerator box or something. Try your local hone depot or Lowe's and ask them if they have any that haven't been crushed and baled yet.
P.M.P.
Stiff Member
5:25 PM
Michigan
I have a old sheet of plywood that leans outside entry door from the building to a post. I hold saw on the other side and blow off with air hose usually nobody walks there.
Maybe a bunch of noodles/sawdust would be good for the grass:confundio:to help soak it up.
juttree
5:25 PM
Wallingford, Ct.
I actually work on quite a few saws and I know the spot at the shop that I blow them off is one hell of an oily mess.
I think i'll try the box idea and if I really want, I could possibly hook up the shop vac to suck it out while I'm blowing the saws off.
blackop555
4:25 PM
U.P mi
Use brake cleaner eat the oil right up do it in a pan with with a old sheet or tarp around it
Gunn
Yay sawz
4:25 PM
Plover wi
I use the tail gate of my truck. Just be sure to park far enough away so the blow back doesn't fling oily smoogers all over your siding :cursing:
5:25 PM
Large plastic tote I use the dollar a can shower cleaner spray it down first let it soak a few minutes then hose it off works great and doesn't burn my eyes like the carb or brake cleaner stuff does.
juttree
5:25 PM
Wallingford, Ct.
I think you guys have the right idea. If I dry up most of the oil it should be fine. I don't really care about the sawdust getting blown outside but mixed with the bar oil it really makes a hell of a mess. My least favorite part of working on saws is getting them clean enough to work on in the first place.
Hinerman
4:25 PM
NE OK
The real root of all evil...
Landmark
Chainsaw Hack
5:25 PM
WNC
I just blow mine off in the drive way. (Gravel) this problem sounds more like a subdivision problem so I cant help. I live in the country and I still use old oil from car to kill the weeds in the drive.
