When to write off a cylinder as bad
Mark71gtx
9:21 AM
Fuquay Varina, NC
When do you write off a cylinder as junk? I ask because I have a questionable one here and I am curious to see what you guys think. I recently picked up a Jonsered 2095 Turbo with a bad P&C. I grabbed up an aftermarket setup and put he saw back together (mostly). I figured I would try to save the cylinder. I used acid to get the transfer out, but I noticed there is a vertical scratch about 3/8" long in one spot and a "pinhole" spot about 1 1/2" away from the scratch. The scratch is about 3/8" from the edge of a port. The pinhole is about 3/4" down from the top of the combustion chamber top. I know no plating damage if certainly preferred, but I didn't want to toss this in my scrap pile if it would still be considered salvageable. Thanks in advance!
Mark71gtx
9:21 AM
Fuquay Varina, NC
Here are a few. The scratch is closer to the port than I remembered...
Mark71gtx
9:21 AM
Fuquay Varina, NC
What I was calling a pinhole
Mark71gtx
9:21 AM
Fuquay Varina, NC
I have not started with scotchbrite or anything yet, I have only removed the transfer with acid. I was not going to waste anymore time on it if it was deemed junk...
9:21 AM
IDK,
I'd hit that spot lightly with a diamond ball, just to blend in any sharp edges.
I just hope the acid didn't get under it. This is one place I wouldn't use acid, but you may not have seen it.
Blend, sand and polish. See what it looks like.
You may lose a drop of starting compression, but at 13,000 rpm, not much is gonna leak past that tiny area.
Mark71gtx
9:21 AM
Fuquay Varina, NC
The piston looked like hell. I didn't see the damage to the lining until I got the rest of the transfer out.
SixGun
9:21 AM
Hackettstown NJ
I would keep it for sure. If nothing else its a good jug to practice porting on
drf255 said it right in above post.
I took down a new 372 with about 8 hours on it , and there was a big chunk of plating gone above exhaust port.
I never would have known if I didnt take the jug off . Dont know long it would have lasted, but saw ran great and piston OK
9:21 AM
I quit using acid for killing a cylinder. The plating was fine until I put acid on it and it got in a pinhole. It popped a big chunk out. I sand with 220 grit and sometimes finger sand with 80 grit.
Frank bierce
6:21 AM
IDK,
Beautifully said. Using acid, there is a possibility the acid got behind the plating causing it to chip. Get it cleaned out good using the stickied mastermind video technique. It would now be a great cylinder to play with..and will probably last a good while cleaned up properly.
9:21 AM
imageuploadedbytapatalk1452936107-390392-jpg.4422
imageuploadedbytapatalk1452936118-051538-jpg.4423
Im wondering what glass beading will do to the plate.
I gotta say, I just played with it and it left a nice finish on the plating. It ground out all the imperfections embedded in the plating.
Im gonna play with removing transfer with it.
