- 5:53 PM
- Feb 10, 2016
- lincolnton nc
sorry guess i forgot to remove the last quote lol before i quoted this thread lol
have you check to make sure its not leaking where the bar oil goes? i has one that was leaking, it was not burning the bar oil one of them weird ones! also when you doing a vac test you need to rotate the crank. i had a echo 280e that would only leak when i put the drill to it i think my drill was set on the number 3 speed setting
I have tried to vacuum test and pressure test many saws and I cannot get a single one to pass and cannot find any leaks with soapy water. Could something be wrong with my mityvac?
I'm a little Neanderthal in my pressure testing. I dunk the whole thing in the stock tank. Remember it's pressure,your forcing the water away. I find the bubbles,blow it off and let it hang till the next day to dry
I often have trouble getting the intake sealed well.
Clean the surfaces first. Gorilla tape over the exhaust, muffler bolted on. Gorilla tape over the block or manifold, carburetor bolted on. You've had this setup leak? If you start clean, you can remove the muffler and carb and it'll usually still hold vacuum.IMO, gorilla tape works better for Vac than Pressure, but is not reliable enough. Usually bolting something over a tire tube over the exhaust works best (and is easy). I often use a 034 muffler spacer, easy to work with.
If the leak is too big to ID with the MityVac, I hook up the bicycle pump to it, jut don't let presser go over 10 lbs. The addl volume helps you find leaks easier. I also sometimes use an automotive stethoscope to hear leaks in hard to reach areas.
Was the only way to ID an intake manifold leak on a MS 250. No other way to access where it was leaking with that stupid cover plate on those saws.
Can you get a pic of the plugs.I have a collection of those plastic plugs that come in new hydraulic lines. One usually fits.
Hose connections leak fairly often! I cut and reinstall the hose. I actually now have a rubber hose on the mityvac and no more leaks!I have tried to vacuum test and pressure test many saws and I cannot get a single one to pass and cannot find any leaks with soapy water. Could something be wrong with my mityvac?
Anytime you forget use RED AMOR oil a full tear down and inspection with vac/pres test is a must or it will self destructI know if you have a saw with a burnt piston you should run a pressure check to make sure the seals are still good but what other symptoms would also lead you to run a pressure check?
I never check pressure or vacuum until I'm done reassembling. I think it's a waste of time on a burnt saw because all the parts that can possibly leak should be getting replaced anyways.
Dunk it under water.I have tried to vacuum test and pressure test many saws and I cannot get a single one to pass and cannot find any leaks with soapy water. Could something be wrong with my mityvac?
Are you having trouble seating bearings?Bearings leak around the bore, oil pumps leak, case gaskets leak...
I always test the case after doing seals before putting a saw back together. Saves having to take it all back apart again to re-seat a bearing or replace an oil pump 'o' ring or case gasket that was leaking all along but not enough to be obvious with a larger leak getting all the attention. Matter of fact a MS361 I'm rebuilding had what appeared to be a leaking PTO side oil seal by all accounts. Turned out to be the bearing bore. Glad I was paying attention to detail.
Had you asked me how far I go on reassembly I would have told you it's before I put the tank/handle back on if I'm putting case halves together. I wasn't trying to one up anyone.Nope.
I'm with you Dan. The plastic hoses that come with the vac absolutely suck balls.Hose connections leak fairly often! I cut and reinstall the hose. I actually now have a rubber hose on the mityvac and no more leaks!
