XP_Slinger
They’re Just Saws
- 10:06 AM
- Feb 9, 2016
- Central NY
When it’s hot, try starting it with just the fast idle set (no choke), if it starts your low end is too rich or your idle is simply too low which can be adjusted with either the idle stop screw or by leaning out the L side. If it doesn’t start richen the Low side 1/4 turn and try startin again. I’m sorry I don’t have the “do this XXX and it will be perfect” answer, that’s just the nature of saw tuning without being there and fiddling with it myself. You have to experiment.Crank what setting, As the saw needs two pulls of the choke to start when not even cold,
this saw guy seems to have made matters worse. So will leaning out the top
also make this / starting worse, that’s where am at now.
I think I need to richen up the bottom a bit,
Reason, if I lean the H am not going to be fourstroking much if any
and that concerns me.
Thanks for commenting
