- 11:23 PM
- Dec 31, 2015
- East Jordan, MI
I’m sure you realize this by now but maybe others don’t. Ethanol contains oxygen. So if you go from being tuned to run non-ethanol and then switch to E10, the added oxygen in the ethanol needs to be compensated for by adding some more fuel.That’s what I run now most of the time. It’s not readily available so if I’m doing a bigger project I run local eth and put the non in before I store it.
Basically, you need 14.6 parts of oxygen to burn one part gas. If you add oxygen into your fuel (like running ethanol), now you may have 15 or 16 parts of oxygen to 1 part gas. Need to adjust the H screw to allow more in
