What octane is best, and why
Woodsman
OPE Member
3:58 PM
The woods
According to the US owner‘s manual that Swabian saw is designed to run on mid-grade unleaded gasoline with a minimum octane rating of 89. Octane values less than that can result in higher operating temperatures resulting in an increased risk of piston seizure.
So, for the Stihl 500 use a non-ethanol unleaded fuel of an octane of 90 to 95? And, a oil ratio at 32:1 to 40:1 ?
Higher octane above 89 helps the Stihl 500 run cooler right?
3:58 PM
87 is fine if it’s fresh. Octane depletes as it gets old, so after awhile 87 is no longer 87. More octane is just more resistant to pre-ignition. The idea behind running 90-95 is so a year down the road the gas in your can or tank still has enough octane so that you won’t have pre-ignition and erode the crown of the piston away.
3:58 PM
didnt someone do some testing and determined that pre ignition in a chainsaw isnt possible?
I believe it’s detonation that doesn’t have time to be possible, but I’m not sure. I have heard the same thing though. One of them is definitely possible because I’ve seen lots of pistons with the exhaust side crown eaten away from using stale gas
pbillyi69
12:58 PM
USA
stale gas the octane is much lower so you think that is burning up the piston because it gets too hot from pre detonation or just getting too hot?
3:58 PM
I’ve had saws keep running after the switch was turned off. Old fuel or low octane causing something inside to glow red hot (likely the spark plug electrode) and acting like a glow plug. Similar to a pre 90’s car dieseling for a few seconds with the key off.
It’s the light ends? or something like it evaporating that makes the fuel more volatile
Nutball
2:58 PM
Mt. Juliet, TN
I mentioned before that I had a 2188 run quieter on 93. 87 & 89 wouldn't do it. Probably gained a smidge of torque. It's the only saw I've noticed the issue with, but I often don't pay attention if it's not my saw, though I still try to get premium for company saws. Mine always get premium.
Woodsman
OPE Member
3:58 PM
The woods
…and I’ve had saws surge at idle like they wanna take off on their own after long hard cuts.
Makes one wonder what’s going on in there while cutting.
Do you remember what octane fuel and fuel/oil ratio you were running in that saw?
3:58 PM
There’s no four stroking 20–30 seconds after the cut. I’d say that’s likely borderline on having enough fuel and it was getting hot. Could also be old fuel causing it to get hot
davidwyby
Rural desert logging
12:58 PM
Extreme Southeast CA
Bof
My big ported saws have to be considerably fattened up in big wood in the heat
davidwyby
12:58 PM
My 2188 is LOWD
