What do you weld with ?
cantgitright
i am Mastermind's other profile
5:46 PM
right place at the wrong time
that was just some pic off the internet...it don't have that stupid head cover...its gotta be almost 7 years old by now...I believe its the original speedglas helmet...
5:46 PM
I used one of those the other day. It's a fresh air setup for hexavalent chromium. Heavy and no fun to use for 12 hour shift.
junkman
Crush it
2:46 PM
pacific northwest
Not sure what kind of dimmy helmet i have ,but i got it off the snap-on truck 15 or so years ago and it still works so i have never upgraded .
cantgitright
5:46 PM
mine is setup for air supply also, just don't have any of it attached...its still heavy though cause of the molded ducts inside the helmet...
Red97
5:46 PM
MI
Prefered hood all depends on the environment...
In my situation here, auto dark, with cooling air is the only way to go. Crammed in a tight space, everything heated to 400* weld, descale, and torch, hard to do with a fixed shade.
Red97
5:46 PM
MI
Also depends on what kind of equipment you are using. I learned real quick my "hobby" hood was inadequate. Mostly with coverage. Never burned my neck doing general fab.
Add 200+ amps that light is a different ballgame.
cantgitright
5:46 PM
The Speedglas has plastic curtains you can install to block out the side windows if you want. I personally like them but I don't have people welding next to me. I can see how someone sparking next to you would be a nuisance.
Their older head gear didn't have a great bottom detent and would open up a little if your head was pointed down. The newer one is better but it still can open up if you tuck your chin and hit the hood on your chest. Lets face it, blinks are mostly for bench work and fab shops. When you're welding all day a fixed shade would be better on your eyes anyway.
Here I found a helmet that might suit you.
heres my speedglas...notice the big gap around 3/8" opening in the second pic...
gap where the lens falls away from the helmet
holding the lens up to where its supposed to be
jakethesnake
I Am The Snake
5:46 PM
Here & Now
Yeah that wouldn't work... You weld daily? I'll scratch that off my replacement list I only weld a lot when others break a bunch of crap or in the winter when I try to make something ... I wanna try to make a heavy round bale feeder my bull is sorta an *a-hole ... He gets pretty sassy with the feeders destroys everything but me so far
