Gentleman
- 7:14 AM
- Nov 30, 2015
- Daytona Beach, Florida
Air leak or straight gas, more than likely an air leak. Never fixed the problem that killed the first top end.
Joe
Of course not. Just throw another kit on. They never believe that it could be an air leak.Did they find the problem that broke the first top end before they put a new one on ?
I once had a customer tell me that "shops in my area don't do pressure tests".I agree with all of the above. Ask the customer if they did a leak down test. The answer will probably be "HUH?"
When you sell the quantity that you do your bound to run into this sooner or later. Most likely often tooOf course not. Just throw another kit on. They never believe that it could be an air leak.
My first question is always "Did you do a pressure test the crankcase?" The typical answer is "No, it had plenty of compression".
