Well this sucks
1:47 PM
I've had a few parts saws in the garage for awhile now. Some 066, an 044, and a 440. And a husky 395. I built a nice 066 from the pile with the help of some new parts as well. Today I figured I'd start an 044 project. I knew there was ring or piston failure, which didn't bother me. I've been able to save most cylinders by cleaning off the transfer. This is more of a failure than a scoring.
#1 An original KS 10mm slant fin
jake wells
no longer here
12:47 PM
ky
jb weld or aluminum filler like randy uses.
1:47 PM
How high above the port is it?
1:47 PM
I didn't measure it, but I'd say .080-.100". Which isn't terrible I guess. It's right in the middle about 3/16" wide. The damage to both cylinders is almost identical. One has a thin gouge up to the top of the exhaust, which might fill in with carbon anyway. The other has a 1/16" spot at the top of the bore where the plating is gone
1:47 PM
In pics 2 and 3, you can see what Mustang Mike was talking about in reference to transfer port quality in the gillardoni cylinder vs ks
1:47 PM
After you cut the band, open the chamber a bit to lower comp. blend the squish band to chamber edge with a carbide ball and create a bell shape, or just radius on your lathe.
I bet with a squish cut, you may be able to grab 98* outa that sucker.
As you know, the amount you take out of the band isn't linear to the amount you'll need to raise the exhaust.
On a 262XP I did, a .040 band cut and .020 squish correction had me raise the exhaust almost .125 to get to 103*. I was quire suprised, and the saws pulling 240psi.
You can also go with the old T port design as well a pointed roof will lower cranking comp, be easy on rings, and effectively open/close later at rpm.
CR888
5:47 AM
Raise the exhaust! oops that's already near done.lol I think with a little work that could be made into a nice runner, its injury could have been in far worse places IMO. You could end up with a highly desireable saw owing you not much, good luck with it.
